another_jim wrote:But the simple fact of the matter is that this conversion to doserless is ruining these beautiful grinders, since the grind chamber and chute were designed from the get go to feed into a doser.
shadowfax wrote:I'd say from firsthand experience of them that Electronic dosing grinders are the wave of the future for the home market *and* the commercial market. I think that most champion baristas would agree with me, judging by the USBC/WBC trends I have seen/read about.
miKe mcKoffee wrote:Timed grinding isn't new, Schomer implemented it long ago. And time and doserless are not mutually exclusive. Couple years ago everyone was ga-ga over the 555/pot mod'ed Anfins. Have the same setup in one of my Majors and hate it. Much prefer stepped discreet 0.1sec increments. The pot is too sloppy for a fast grinder and is subject to bumping. I do fully agree to benefits of timed grinding, especially in a commercial environment. One of my cafe grinders is a lowly SJ (with doser tape mod of course), works marvelously plugged into timer currently set at 6.5sec for City+ Ethiopia Sidamo SO double.
As far as doserless ran an SJ with Mini-E funnel and static grind and found it messier than doser. Went back to doser. But that's just me.
So the Mazzer engineers scratch their heads about lunatic Americans, then paste on a funnel, a silly little propeller, and a grid on the outlet to control static. And guess what? The grinder doesn't work right. Gee, what a surpise!
Tom (dsc) really needs to make me one...
shadowfax wrote:You're right about the non-mutually exclusive bit. Makes me think of Dave's pic of Michael Elvin's Major E + Elvinator'ed doser. I've also used the Anfim with the stupid little pot mod. So darn sensitive, I thought it was the stupidest thing I'd ever seen, so sensitive I found adjustment ridiculously irritating. Infinite grind adjustment and small steps (Mazzer has 0.05s steps) is easily the way to go.
Doserless SJ--I have used it too. I made one. If you haven't used a properly functioning Robur E, I don't think there's much point in trying to compare it to other Mazzers, or any custom modding you may have done. It's way nicer--way less clumps, and really hardly any static. The real problem with the Robur is TONS of waste if you're making < 100 shots a day.
That said, I have my robur set up with an Elvinator and a photo enlargement timer; I really like this setup, and I am honestly glad I didn't spend the extra for the E. I wouldn't mind spending some money on a slick timer on the lid like the E, though. Tom (dsc) really needs to make me one...
gyro wrote:So the new burrs arrived today. Got them installed and churned through 2 pounds of coffee. Visually the burrs were smoother looking, but still quite rough in places. Last go on the original burrs (after 10+ pounds) I was doing a double in 8.5 secs and seemed very inconsistent and the grind felt coarse. It started the same today, but within a couple of pounds it has settled considerably and is doing a 17 gram double in 6.5 secs with reasonable consistency. The grind felt more like I am used to from the Mini E.
There are still little coffee cubes coming out, but they are much less dense than before, and a simple finger sweep makes them disintegrate nicely with no WDT, no channeling.
Still seems slower than it should be, but perhaps as it seasons a bit more it will get a bit quicker. The grind is much better than the last set already.
Cheers, Chris
gyro wrote:Well I've had around 5 pounds through the machine now, and its definitely speeding up and becoming more consistent. Its down to 5.5 secs now for a double. Mazzer are apparently starting their own production line for conical burrs, the ones I received are from their external supplier however.
Javacat wrote:Great to hear it finally worked out for you. What is the grind and taste comparison to the two sets of burrs?
