RapidCoffee wrote:Theoretically, I agree. In practice, a bean load of several double shots in a minihopper appears sufficient for consistent grinding. I experimented with this some time ago, and you can too. Starting with a weighed column of beans (say, 6x17g=102g), grind and dose* one shot after another until the beans are used up, without changing the grind setting. Extract each pour for a fixed time (say, 25s) and weigh the shot. At some point the extraction will begin to flow faster, and the extraction weight will increase. That will give you a rough indication of the bean load required for consistent grinding.
* obviously you need to use a fixed dose weight
Yes, this makes sense. I like the single dose idea because there's no waste, and I can change grind settings and beans on the fly. I've had shots prepared by Jim that rival the top cafe's in Chicago for taste and quality. I guess what I would want to know is whether consistent grinding (based on your example above) leads to better tasting shots than with single dosing (which would have some grind inconsistencies)?
