First Impressions on upgrading from Mazzer Super Jolly to Compak K10 - Page 2
Postby Sherman on Sun Jun 26, 2011 8:17 pm
How would one perform such a task? My curiosity is piqued!
Your dog wants espresso.
LMWDP #288
Sherman
Postby JohnB. on Mon Jun 27, 2011 9:45 pm
Sherman wrote:How would one perform such a task?
Remove the following parts from the doser: the sweeper adjustment cap/cover, the c-clip from the shaft, the upper sweeper vane assy., the nylon washer & the exit hole cover plate. Now reassemble installing the nylon washer first so that it goes under the cover plate. Make sure the two tangs on the front of the plate drop into the two slots in the doser body. Also check that the 3 pins in the under side of the upper sweeper assy. are fitted into the 3 holes in the top of the lower sweeper cover. I left the c-clip off mine to speed up future full breakdown cleanings.
LMWDP 267
JohnB.
Previous
Return to Grinders
