Fiorenzato T-80 Motor Removal
Postby Clint Orchuk on Sun May 15, 2011 4:56 pm
I wanted to either paint or polish my Fiorenzato Grinder. It's easy to get the top assembly apart and to remove the base from the body. Does anyone know how to remove the motor from the body? Is it a pressure fit? I don't see any obvious screws.
Thanks.
Clint Orchuk
Postby zubinpatrick on Mon May 16, 2011 6:24 am
I looked at this:
http://www.eunasa.com/en/despiece.php/a.../10624/t80
Looks the same as a SJ the 2 ends of motor are held by press fit bearings....remove the brushes first the use a puller or similar to ease the motor out....BTW why remove motor to paint? Just seal it with tape and plastic and do the body.
zubinpatrick
Postby Clint Orchuk on Mon May 16, 2011 10:00 am
Thanks Zubin,
I wanted to get the motor out if I decide to polish it. It's awfully heavy to hold up to a buff wheel to polish it with the motor in.
Clint Orchuk
Postby orphanespresso on Mon May 16, 2011 4:50 pm
It can't be and heavier than that 2group Astoria that you lug around!
orphanespresso
Postby Clint Orchuk on Mon May 16, 2011 7:40 pm
Game, set, and match, Mr. Garrott.
Clint Orchuk
Postby JohnB. on Mon May 16, 2011 8:57 pm
The SJ rotor/burr shaft assy. can be removed fairly easily but the body needs to be heated in an oven if you want to remove the field assy. If the T-80 is the same I'd remove the stator & leave the field in place.
LMWDP 267
JohnB.
Return to Grinders
