I'm with Jim. You might want to get a little professional evaluation on the stalling issue.
As far as burrs go, you should be aware that there are several different types of mounting arrangements for different burrs, and indeed even the "71" and "68" mm burr sets are identical in terms of cutting surfaces (see the ancillary discussion
here). I've pulled the burrs on a Robur and Nino and had a good look at my Compak K10's burrs. The outer burrs on these three grinders are not compatible in terms of mounting, as near as I can tell. different mounting hole sizes, different styles of alignment ridges, slightly different outer diameter. You need to make sure you get the right burrs for your grinder or have an ironclad way of returning any test burrs you want to try sight unseen.
