Faema MPN - how to remove burr carrier?
Link to "Faema MPN - how to remove burr carrier?"by fergusstew on Wed Jun 10, 2009 11:21 am
Hi,
I'm rebuilding a Faema MPN, about 1995 vintage.
I'm stuck. I can't figure out how to separate the lower burr carrier (gold-colored parts in attached photo) from the motor shaft.
I've seen the exploded parts diagram on this forum, and it looks like the gold colored stubby shaft with a helix on it should come off separately, and then the burr carrier, but how?
Thanks for helping me!
Fergus.
fergusstew
Link to "Faema MPN - how to remove burr carrier?"by HB on Thu Jun 11, 2009 10:40 pm
Assuming it's pressed on a tapered shaft like the Mazzers, this may work:
Paul_Pratt wrote:An easy way is to use long bolts and tighten them in sequence. The bolts push against the main body and force the carrier off. The risk of damage is low because the amount of force required is very small.
See Removing Super Jolly lower burr carrier for more.
Link to "Faema MPN - how to remove burr carrier?"by farmroast on Sat Jun 13, 2009 11:39 am
That's the way I do it to. Tighten slowly and evenly
Ed Bourgeois
LMWDP # 167
http://coffee-roasting.blogspot.com/
It's about the dirt.
farmroast
Link to "Faema MPN - how to remove burr carrier?"by espressme on Sat Jun 13, 2009 2:12 pm
I looked at my MPN. I have not dissembled mine that far. There are two opposed flats on the shaft above the helix. I would think that these would allow the use of a close fitting wrench to turn the helix section as a nut. That nut may hold the lower burr carrier to the motor shaft.
While you have it apart, Here are a couple of threads here on handy modifications of the MPN to make it easier to use and clean.
#1 HERE
#2 HERE
Many Happy Thwacks!
-Richard
richard penney LMWDP #090,
espressme
Link to "Faema MPN - how to remove burr carrier?"by fergusstew on Tue Jun 16, 2009 11:50 am
Hi,
Thanks for the help, it worked! There are flats on the brass shaft, and it unscrewed from the main shaft. It's a left hand thread. Then the burr carrier just came off. Here's a photo of how I did it.
Fergus.
fergusstew
Link to "Faema MPN - how to remove burr carrier?"by espressme on Wed Jun 17, 2009 11:23 am
Hello Fergus,
Thank you for the feedback! It may help other folks in the future!
Many Happy Thwacks!
-Richard
espressme
Return to Grinders
