I received a very nice reply from Federico Fregnan at Elektra regarding the new grinder. I assume it's ok to post this information, as it will generate some buzz.
Description as it currently stands (sorry for the bad formatting):
"Elektra NINO" coffee grinder controls
Technical/Functional Specifications
Rev. 0 dated 21/02/05
Rev. 1 dated 09/06/06
Rev. 2 dated 31/10/06
General features
The card controls the coffee grinder motor unit by programmed timing.
Grinding duration is set by pressing the "Single Dose" or "Double Dose" button, while grinding start up is controlled by the microswitch.
Grinding will start upon pressing the "filter carrier on" microswitch.
To display
1. programming parameters
2. alarms
3. dose counters
the machine uses a 2 line, 16 character LC display
The grinding process is shown in 0.1 sec steps on a 25.5 sec scale.
The motor is controlled by a 16 A triac relay.
The relay may be replaced by a static relay positioned outside the card.
Functional features
* As you switch the coffee grinder on, the following message will appear on the display:
" ELEKTRA"
"Ver. X.X"
and, after 2 sec,
"Grinder"
"Ready"
* Press the "Single Dose" or "Double Dose" button to select the relative grinding time.
The machine is set on "single dose" as default choice.
* To start off grinding, close the "filter carrier on" microswitch (by placing the filter carrier in its proper lodgement).
During grinding, the display will show the message: "Single Dose"
Or "Double Dose"
to stay on throughout the grinding process.
Five seconds after grinding has stopped, the display will again show:
"Grinder Ready"
Language programming
The display can be programmed to use the English language.
To access this function, switch on the card by keeping the "Single Dose" and "Double Dose" buttons pressed for at least 3 seconds.
The display will show: Italiano
Press the "Single Dose" button again to display: English
To confirm, just switch the card off and on again.
Programming
To program grinding times, proceed as follows:
Switch on the machine by pressing the "Single Dose" button and keep it pressed for at least 5 seconds.
The display will show: Prog T. sin.
XX,X
The LED associated with the "Single Dose" button will light up to indicate that programming is on.
The "Single Dose" and "Double Dose" buttons can now be used as increase and decrease buttons.
Change the value as you wish and confirm by pressing the two buttons together.
You will automatically be taken to grinding time programming for double dose coffee.
The display will show: Prog T.doub.
XX,X
Change the preset value using the "Single Dose" (+) or "Double Dose" (-) button, and confirm by pressing the two buttons together as before.
Pressing the two buttons together a second time will take you out of programming.
Counter display
Dose counters can be displayed or zeroed by switching on the grinder with the "Double Dose" button pressed for 10 seconds.
The display will show: Res. sin.?
XXXX
If you press the "Double Dose" button, the display will show: "Confirm"
Pressing the "Double Dose" button a second time will zero the counter.
If you need to only display the counter, wait for the 5 sec time out to expire, which will cause the "Confirm" message to disappear.
The same procedure can be applied to the double dose counter by pressing the "Single Dose" button.
The display will show: Res.doub.?
XXXX
If you press the "Double Dose" button the display will show "Confirm"
Pressing the "Double Dose" button again will zero the counter.
Pressing the "Single Dose" button will end the procedure, allowing service to be resumed.
Alarms
A control is provided for the "filter carrier on" microswitch.
If the microswitch is closed when the machine is turned on, the display will show the message:
Doser out of order
and the grinder will be irreversibly blocked.
A micro switch check is also carried out 5 sec after grinding has ended.
If the micro switch appears to be closed after the 5 sec time out, the same message will come up on the display and the grinder will be irreversibly blocked.
For service to be resumed, restore micro switch function and switch the grinder off and on again.
All components are validated according to UL/VDE/CSA.
The card complies with the CEI 61-150 regulation (EN 60 335-1 European Regulation) governing the safety of household appliances and similar machines.
It also complies with the European directive on EMC (electromagnetic compatibility).
Working temperature is between 0°C and 70°C.
