Whale wrote:Disclaimer: I am not a qualified Electrical anything. The following is some of the information I have found when the capacitor of my roaster melted down.
There are 2 type of motor that use a capacitor. They are dubbed Capacitor Start motor and Capacitor Run-Start motor. (...)
Thank you for the explanation, it helps a lot, to understand the issue and inner workings of the grinder. I will now read up on the capacitors, thanks for the push in that direction. Hopefully, I will talk to a grinder technician (of Mazzers, not Elektras) on Monday-Tuesday, maybe he will have something to add too.
I doubt it is the key or something with the burrs/shaft, since the grinder was working ok for a year, before this happened out of the blue.
p.s.: I have also located an italian manufacture of the motors for Nino, so maybe they will be of some help too.
