Mark,
I got the K30 hopper from Mahlkonig USA,Inc. The Hopper without top and cutoff slide was $45. plus shipping.
It was one they had "around" so they threw in the top for free. Very professional folks to work with, I highly recommend using them. My set up is a work in progress but you can see if the hopper appeals to you.
I'm glad to hear that your Nino is glitch free. I have a couple of issues to work through but I'm confident they will get resolved. I'm really hoping to find a simple reason for the grinds backing up in the chute. Perhaps I have a chute that has something wrong with it I'm just not seeing. I removed the shell today to have a closer look at the chute assembly and did find 2 piles if grinds atop the motor directly below the chute. The chute either leaks or I didn't get it inserted all the way the last time I removed it. fortunately, perhaps the fan offers a little protection to the motor in blowing the errant grinds out the top. My chute turned out to be the newer style and you can see that it is hand made which is nice. I also found evidence of a pinched wire which may have been the reason for the problem I had earlier with trying to reset the grind duration. I have a bunch of pix I will post as time permits.
Tom
