mteahan wrote:It would be interesting to see if there is a difference and if any of that can be attributed to the cutting angle.
Sorry for delay, the last week has been hectic and this weekend did not afford much time for testing.
As you know, I had some difficultly properly seating the bottom burr because the centering ring was a teenie bit too large for the Duranium burrs. After several attempts and some "persuasion," the burrs were installed and in short order, the pours looked reasonable. It may be my imagination, but in addition to being really really fast, the taste profile seems different. A lot more chocolates, almost to the point of tasting like a tight ristretto despite my usual brew ratio.
I have focused on the Mazzer Kony / Super Jolly + Duranium burrs since my time with the Titan's is rapidly coming to a close. After dialing in both grinders this morning, I only had time for two side-by-side blind taste tests using Counter Culture's Aficionado blend. The blend seems lower in acidity, less fruity, and bigger in chocolates than I recall; I'll have to ask Peter if its flavor profile has shifted or my memory is failing (or both!). To the results:
Round 1:
- Mazzer Super Jolly:
Crema appearance: 4.0
Crema persistence: 4.0
Tactile balance: 3.5
Taste balance: 4.0
Overall: 4.0 (yum!)
Mazzer Kony:
Crema appearance: 3.0
Crema persistence: 3.0
Taste balance: 3.5
Overall: 3.5
Taste balance: 3.0
Overall: 3.5
Mazzer Kony:
Tactile balance: 3.0
Taste balance: 3.0
Overall: 3.0
I look forward to hearing Nick's thoughts on them.
