DLC coating seasoned burrs
Found a local company that would be willing to dlc my hg-1 burrs but I was thinking about seasoning them first. Hoping for some feedback on this idea from anyone experienced with dlc coatings (frank)
- Terranova
- Supporter ❤
Sorry but I really cannot say how it affects your hg-1.
For an electrical grinder it builds up much more retention and static.
Thanks for the reply, so are you saying that dlc coating actually makes static more of an issue??
Also, what I was really asking was if you've ever dlc coated seasoned burrs?? I was thinking of seasoning them in coated so it would go much faster and then having them coated.
- Terranova
- Supporter ❤
No, I just said that it is an issue for an electric grinder.leozava wrote:so are you saying that dlc coating actually makes static more of an issue??
The hg-1 only works with RDT, so not sure if RDT compensates the low electrical conductivity of Carbon.
Seasoning the burrs before the coating makes much more sense than after, yes of course.leozava wrote:Also, what I was really asking was if you've ever dlc coated seasoned burrs?? I was thinking of seasoning them in coated so it would go much faster and then having them coated.
They will get cleaned very accurate before the coating process even if you clean them by yourself.
- Bluecold
Coating only increases lifespan right?
LMWDP #232
Thanks for the replies frank, I'm going to give it a shot and report back in a couple weeks.
That's what I was thinking, get the burrs where you want them then dlc coat them so they stay there.
- Terranova
- Supporter ❤
According to Christian Klatt the Mahlkönig Product Manager it has an impact on patricle size distribution.Bluecold wrote:Coating only increases lifespan right?
Different coating different particle size distribution.
Source: Youtube "Grinding, what is the latest news" 1-4 (each is 15 min)
Sasa Sestic and Colin Hamon claim that they get a higher EY from coated burrs.
It could be just marketing because of Anfim and the Mythos. (They are both involved)
If I change from original to coated burrs on the same grinder (flat burrs), both burr sets exactly the same size, built quality, sharpness, same alignment, then I have to grind much finer with the coated burr set for getting the same flow rate.
Of course I cannot say if it is better or not, but it has an impact.
- erics
- Supporter ★
"Seasoning" grinders means different things to end users. I defer to your knowledge of grinder/grinder burr manufacturing but this needs a little more objectively.Seasoning the burrs before the coating makes much more sense than after . . .
There exists ZERO pics of grinder burrs on this site before/after "seasoning". Possible, someone can post same.
If I were to purchase a 1K grinder, I would hope that it would work as intended "out of the box".
- Terranova
- Supporter ❤
A grinder with "pre seasoned" burrs, ready for use "out of the box" costs a bit more than 1kerics wrote: There exists ZERO pics of grinder burrs on this site before/after "seasoning". Possible, someone can post same.
If I were to purchase a 1K grinder, I would hope that it would work as intended "put of the box".
Your statement seems contradictory.
On one hand you say that you want to see if there is a difference between brand new and seasoned, but on the other hand you know that the hg-1 doesn't work "out of the box".
So there must be something about it right ?
The grinder works wonderfully "out of the box" and does exactly what is says it'll do. I've had the grinder for a couple weeks and notice it "settling in" as the burrs wear in a bit but that's a well known fact. As soon as I put a little more coffee through the grinder I'll have burrs dlc coated and see how that goes from there.
