Who would like to design their own grinder?
It will would have no hopper and only enough coffee beans for a triple would fit at one time. The grounds would drop straight down into a portafilter.
I'd like a grinder that used a nice DC motor (no start capacitor issues) with big cool running burrs. (Mind you conicals would also be nice). The first system produced would be more of a test of the motor and electronics and would not be expected to produce anything that useful.
Ideally all parts could be designed by CAD and produced via http://www.emachineshop.com as I do not have a machine shop.
1. Procure a grinder head assembly (San Marco's appear to nicely detach the grinder head from the motor mount). A thread in the wanted area of CoffeeGeeks is seeking one out. Alternatively find suitable machinable brass carriers.
2. Motor control unit. A custom AVR microprocessor controlled system with an LCD display and a DC motor. This will run the motor at the speed we desire. (I'm an Electrical Engineer that does software programming so this part should be one of the easier parts for me to get done). Electronic start/stop/timing with built-in micro-switch inputs for control. BTW: This is a relatively inexpensive compared to the burrs and carrier.
3. Sweepers that cleanup
4. Gears driven instead of belt driven (hate slippage in pulley system).
5. Other ideas?
Your thoughts? Pictures of assemblies/ideas that people think are important would be most helpful to me.
Mark
