there's more info in this topic:
Versalab M3 grinder owners
this beaing the most important part (straight from Laura at Versalab):
-- The shaft of the grinder is held quite rigidly in a pair of ball bearings. A perfectly trouble free arrangement that had problems only in the first few grinders. [Mr.Schulman's grinder is serial number 9.] We made a rather tiny change (.010") and all has been quite perfect since.
Still, the shaft is quite long and I'm amazed there are no problems with the shaft wobble, especially since those are ball bearings. I'm curious how far away from the burr the bearings have to be seated in order to eliminate or almost eliminate shaft wobble problems. If I can for example put two HQ roller bearings, 1" from each other on the top of the shaft and that will work I'll be interested in that idea.
Regards,
dsc.
