by arriflex on Wed Dec 02, 2009 2:52 pm
Dsc, it seems logical to me that the springs press against the adjuster, and that the force from the grinder to spread the burrs not be counteracted by the spring but by the more static adjuster. In my design, as well as yours, that would mean the springs should push the carriage up against the adjuster just as the grinding motion pushes up against the adjuster. Just my opinion.
Sweet skilz in autocad John! If I were to try and do that in Sketchup, it'd probably be best done with Ruby as a plugin rather than using the built in tools. Mark we should be able to import it into Sketchup with a .3ds file. John, were you working off any theory in deciding the basic shape? Or was it more freehand?
edgar
