So here's 7.30 in the am:
Yeah yeah, I know I am still using the cheesy plastic tamper. But budget is pretty tight for now so that will have to wait. And the temp is on the low side. I guess that's inevitable because of I was filming just 10 minutes away from waking up.
My procedure:
i) Fill in the water
ii) Warm up for 7+- minutes, until the false pressure build up.
iii) Bleed off false pressure
iv) Weigh your beans & get your cup ready.
v) By the time I put my beans into the hopper throat, the Cremina is fully up to temperature.
vi) Pull a few blank shots to warm up the group.
vii) Grind, thump and level. Not many fancy moves.
viii) Load and preinfuse. Pull away!
ix) Enjoy the espresso and don't forget to clean up.
I love how the routines are becoming so simple and quick because of the Major+Cremina combo. I used to do WDT (way back with Capresso and Super Jolly) and take minutes to prep the basket but I find that this doserless Major is making them (kinda) obsolete. That's because Major is producing even grind at least as fluffy as a Vario but is way superior than it in certain aspects. So I am spending more time enjoying the espresso and less time in prep. But of course, I am eager to get a bottomless pf or get my pf bottomless to check how's the extraction going. That would be a waste though to cut away the bottom and throwing away the nice double spout.
Usage:
As I am making 3-4 shots maximum daily, I am a strong advocator of single dosing. Loading the hopper with beans and dial in with time (with the Vario) just doesn't cut it for me. It takes beans to dial in and by the time I am getting it dialed, the beans start aging and needed more adjustments. It's just not worth the effort for me (mainly because of my usage pattern). But I know for others it's a valuable tool. I am a cheap person
Grind retention:
Honestly, I am really surprised(pleasantly) with this. Without sweeping, the chute averagely holds about 0.1-0.3 gram worth of grounds. I was expecting more like 10-12g retention that I am hearing with titan grinders.
Grind quality:
Visually, the grind into the portafilter is fluffy, even and no clumping. As for the taste in the cup, I am not a great taster but my espressi experience has all been pleasant with it. And guess what, Major has 83 mm flat burr (biggest diameter espresso flat burr, correct me if I am wrong) and what's more it's Mazzer. That should mean something even if it's not reviewed in the titan grinder project, doesn't it?
Static:
Normally, there are very little static. Not enough to bother me. But I did tried wiring the funnel to the ground plug at the bottom of the plate. I am not sure whether it's a placebo effect or it has really been working. But recently I has been getting no static. Or could it be due to the more humid weather?
Grind time:
One word, quick. Two words, fantastically quick!
Adjustment:
I would say as compared to Vario it's more intuitive. I was always confused whether I should move the micro or macro lever first. I had also always accidentally touched and moved the lever cam. No such issue with Major. But notice, this is 99% due to the user (me) issue, not the grinder, because I am new to using Vario. Another point is that the Major's adjustment doesn't need that much of fiddling once you find your range.
How it looks. Being a poor student, I always make my mod from cheap things available in/around my apartment. Allen key for easy adjustment, aeropress funnel, funnel from spoiled lamp.cost=0. If only I had more money, I would get a aluminium plate or even the OEM plate to make it more elegant. A paint job would be a good idea too.
Inside the funnel and chute:
My setup that I have settled with, no more upgraditis.
Conclusion:
Mazzer Major is a great grinder that suits my usage patterns. It might not suit everyone but it's the perfect choice for me. Low beans waste, low retention, low maintenance, fluffy high quality grind and long lasting, what more can we ask from a grinder for home use? One thing I learned is that when you get over the decent espresso grinder price range, it's very difficult to notice the slight difference/gain in the taste, especially for a beginner like me. So, I think after the threshold, it's all down to the convenience factor that suits your usage pattern. In that sense, Major is the one for me. I am just curious that there hasn't been that many reviews for such a great grinder. Just sharing my two cents albeit a long one. =P
