The Macaps are dosed via Saunders/LPL ET-500 0.1s timers. With lighter roasts, dose weight accuracy is really quite good.
Last time I checked the MC4, for 15 shots over 5 days, the dose was 8.7 or 8.8g in 8.5s
A few months back, a normally Milanese roast coffee blend migrated way south of Napoli : MUCH darker and oilier. Grind time and shot consistentcy went south along with it. [One useful side effect of the bean damper is one can visually see the feed rate. Normally quite consistent with drier coffees, oilier ones feed somewhat jerkily.]
I purchased a Sulawesi Toraja SO, roasted darker still. Grind times and shot consistency for the same measured weight are abysmal.
Reasoning inconsistent feed equals inconsistent grind with portions ground ala single dose and portions loaded hopper, I adjusted the MXK grind for single dose. Voila, consistency returned.
Point to ponder : Is Titan consistency due to larger throats and steadier burr feed?
