Hello again:
Ken Fox wrote:... done a lot of machine mods ...
Indeed ...
Your Cimbali Jr. PID installation was the guide to doing mine.
Thanks for all that you've written about it, it was very useful to me.
Ken Fox wrote:... because I had a goal in mind, a "shortcoming" ...
So do I, maybe our concept of "shortcoming" is different.
My initial idea is to see if I can get rid of the doser, which I do not like, that's all.
I also accept that it could not be a wise thing to do and may just have to get used to having one.
Ken Fox wrote:As to "carrier wobble" ...
I don't want to stray too far from the original topic, but will say this: I only mentioned the Max's "carrier wobble" as an illustrative side note. That said, the Max (as I understand it) is a horizontal flat burr grinder, with an additional conical 'breaking' burr set but basically it's a flat burr grinder.
There's been loads of text written at HB about the issue of grind particle size, size distribution, fines, etc., so I won't delve into that, just say that at times it seemed a bit far fetched.
But then that's just me.
Independently of that, I'm sure that we can agree on the fact that if for whatever reason a grinder's set of flat burrs do not share the same vertical axis ie: cannot eventually meet on the
same plane (within reasonable tolerances, no electron microscope needed) and on top of that, their not doing so is a haphazard event (wobble), the consistency and precision standards that we should or at least have been led to expect from a quality commercial coffee grinder will never be met.
So, while the
'a la Rocky' fix is a reasonable makeshift solution, I have seen other grinder manufacturers implement OEM solutions that address this specific issue, eg: a set of three or four spring loaded rods that firmly push the upper carrier upwards to keep the male/female threads tight against each other, resulting in practically no wobble. I have two other AR made flat burr grinders at home, one from the early 60's and the other from the late 90's with this type of device and they have no wobble.
Ken Fox wrote:... understand the design parameters ...
... mistake either intentional design or when a product is in fact within specs ...
... do not really know how the equipment was engineered and why it was done that way.
Well ...
In my experience with quite a few mechanical artifacts (from washing machines to cars), most of the time these aspects you mention are exclusively cost/profit related. If the Cimbali Max carrier assembly (for whatever reason) was manufactured with design specs indicating that upper carrier wobble (say, within +/- 1.0 mm) is acceptable, then for the manufacturer it will
always be within spec, no matter what anyone else says about it.
David R. wrote:... historical origin of the idea that there should exist doserless espresso grinders.
... never really considered a major benefit.
Could well be so.
But I think that it depends on the kind of use you give your grinder.
David R. wrote:... if Rancilio had wanted their hopper lids to be tight ...
I am really not so sure about that.
The expertise 'is' there, there's
no doubt about that.
But tighter tolerances (in anything) usually mean higher manufacturing costs.
David R. wrote:... selling a doserless version of the Rocky for more than the doser version.
Indeed ....
At the time I found that to be both funny and hard to understand.
Thanks a lot to both for your input.
Much obliged.
Cheers,
CIV
