Hello all:
Before I continue with this post, I'd like to say something: I have a Cimbali Max because I purchased it, paired with a Cimbali Junior D/1, both in almost new condition and for a
very low price, ~20% less than what a Rancilio Silvia V3 costs today in the US.
Quite evidently, a once in a lifetime oportunity.
Had I been able to choose, I would have undoubtedly chosen a Cimbali / Aurora single lever and a doserless grinder which could be used without a hopper. But it was not the case as imported espresso equipment of this quality is very scarce in AR and when available, in so-so shape and quite expensive, as well as any available parts.
That said, I am aware that the object of my present ramblings are to try to be able to do what I want (double dose grind, no waste and no hopper or doser) with what I have (a Cimbali Max with a huge hopper, a tendency to 'pop-corn' and a non-removable doser).
Not an easy task, difficulties and contradictions abound as the Max was designed for
different type of regime and environment, but it's what I have to work with.
And I'm very happy with it. =-)
From previous observations, I have am convinced that grind retention inside the exit chute is (IMO, of course) the main or at least one of the main problems that affect grinders with burrs on a vertical axis, flat or combination conical/flat. My idea is that the combination of carrier vane design and exit chute length are the culprits as they do not address the change of direction the grinds need, basically a 90° turn downwards. But that's just 'my' idea.
In any case, this topic has been discussed to a certain length here:
Lower burr carrier design for reduced clumpingI have disassembled the Max's doser mechanism as explained in my previous posts and been able to see exactly how the grind falls from the exit chute into the doser cavity, only to find that it is no exception: the Max grinds faster than what it can send/throw/push/extrude or whatever the grinds towards the doser cavity and the grind piles up inside the exit chute.
So I'd say that
this is probably the first (and main) problem to overcome. If this could be solved adequately, I think the rest, getting the grind to the PF in single doses, may be much easier to achieve.
There is no possibility of making any mods to the Max's grinding chamber/carrier vanes. And even though the vanes rotate
very closely to the chamber walls, (much like the Barazza Vario), the ground coffee still piles up inside the (apparently much longer) exit chute and is pushed forward as the grinding continues.
From the thread mentioned above:
shadowfax wrote:The Vario seems to keep its retention at next to nothing by making the grind chamber hug the burrset as tightly as possible
... I think the design defeats the clumping inasmuch as the chute is so narrow ...
Lowering the feed volume could solve part of the problem as the grind will not pile up in the exit chute but the lack of a column above the conical/flat burr set will generate popcorning and apparently there's also the possibilty of static generation.
yoonkk wrote:... and to remove the remaining grinds in the exit chute I apply a few puffs with a hand "pump/blower".
I find this to be an interesting idea but it entails blowing air in the direction the grinds
come from.
I have done it with other (smaller) grinders I have and now tried it with the Max: blowing air (basic, blowing through a 55 mm tube stuck over the burrs) from where the beans are fed once the grinder stopped and I've found that it works really well, leaving very little behind.
ie: Applying positive air pressure in the direction the grind is going,
towards the doser chamber.
If positive air pressure could be applied
during the grinding process (and not after) it may well be that much
less pressure will be needed to move along the grind and keep the chute empty. ie: a small amount of grinds are easier to move along than a pile-up or important accumulation of them.
I have not thought about how this could be done yet, but I'd appreciate any comments.
Cheers,
CIV
