bRobert wrote:There seems to be more "float" in the grinder adjustment. Once the burrs are noted to touch, one has to back off quite a bit to stop the burrs from touching. The Mazzers have a more discrete zero and the burrs stop touching with just a slight coarse adjustment.
HB wrote:All the Mazzer grinders have a similar burr adjustment mechanism. The upper burr carrier "floats" on three springs. The chrome adjustment collar encircles the throat of the collar, holding it at the desired height above the fixed lower burr assembly:![]()
Threaded adjustment collar in chrome and upper burr carrier (L), close-up of upper burr (R)
This close-up shows how the lower portion of the spring suspension of upper burr carrier assures no thread slop. Under the tension of the supporting springs, the carrier is pressed tightly against the bottom of the chromed adjustment collar:![]()
Lower burr mounted atop the motor's shaft (L), close-up of support spring (R)
(from Mazzer Mini Component Photos)
