sweaner wrote:Robert, I have a Mazzer Mini, and I suspect that even it is the largest grinder in MY neighborhood.
Scott...as much as I hate to say this(
woodchuck wrote: I found the Robur ran a bit faster than the K10 as well. It does take a little practice (and a lot of coffee) to get used to the speed. The K10 was the WBC model and some folks have suggested it runs a little slower than the standard model.
Jacob wrote:That's the outside diameter. As far as I know the inside diameter is almost the same!
eastpresso wrote:Err.., afaik 3mm difference is 'almost the same'?The difference in rpm is not so small...always provided the (Italian and Spanish) specs are accurate
Both grinders are ridiculously fast for the home anyway, so no point in arguing.
IMAWriter wrote:I can't imagine why folks AT HOME would require anything faster, especially if grinding directly into the PF/basket. My gosh, I did 16 grams in around 5 seconds with the Duraniums!
IMAWriter wrote:Having owned 2 SJ, one with Duranium burrs, I can't imagine why folks AT HOME would require anything faster, especially if grinding directly into the PF/basket. My gosh, I did 16 grams in around 5 seconds with the Duraniums!
AndyS wrote:Once you get used to fast grinders, 5 seconds seems a little slow, actually. A three-phase Robur at 60 hz does a double dose in about 1.5 secs. That extra 3.5 secs really comes in handy for doing essential stuff like spitting or scratching one's crotch.
woodchuck wrote:First off, I have to point out that I have a Macap M4 which I really like(d) - a few weeks with these guys and I am now suffering from a bad case of Upgraditus.
To be truthful, though, I normally run the Robur at 36 Hz. At that speed it takes a laidback 2.5 secs to grind 14g. This is OK, though, because previously, with all that scratching time, I was beginning to get a bit sore.
