by Euology101 on Wed Dec 28, 2011 10:43 am
Good morning/Happy Holidays everyone!
I'm sure most of you are still on your holiday vacation so hopefully someone out there with a Compak K10, can chime in...
Background: I've had my Compak K10 (Pro) for about 2 months, bought it new from ChrisCoffee. I obviously did a ton of research when buying and found that most people can easily single dose this unit, which is good for me. My beans are fresh, anywhere from 3-10 days out of roast, occasionally frozen, but I would say once a month I'm using frozen beans, if that.
Issue: I weigh out 18g, plop it in the throat, put an empty Spice Island jar above it, and pull the trigger. About once a week it'll clog, burrs won't budge, I can hear the motor running, but no grinding. I have the unit on a darkroom timer (gralab 450, with a foot pedal). I thought maybe the start capacitor was weak, but I'm not much of an electrician, to figure that out. If I empty the throat, and coarsen the grind, it will spin free. This takes about 5 minutes, and quite frankly at 5:30am... not something I look forward too.
Another thing that I "can't" rule out is that with the foot pedal, the slightest amount of pressure flips the switch, and I've actually gone to press it, and actually turned it On then Off again in like a 10th of second, and wonder if maybe that tiny amount of time was enough time to lodge a bean which was enough to stop the burrs.
Has anyone else had this issue? Any thoughts? Any other good work arounds for the single dose? I personally hate the "On/Off" switch the unit comes with, and I enjoy having a timer, so I can hit it and walk away.
Thanks for your help as always!
-Justin
