First, disassemble the sweeping vane assembly. Unscrew the dose adjustment knob (I had a hard time with this at first be cause I didn't realize that you _could_ unscrew it), remove the retention clip, and the vane assembly will come out. In descending order, it comprises:
- upper vanes
- plastic washer
- dispensing chute plate/block off plate (has 2 small detents that allow it to fit snugly above the dispensing chute)
- lower vane cover, which has 6 spokes and covers each of the bottom vanes
- vane spring
- bottom vanes
Next, apply some type of heavy tape or velcro to the leading (or trailing) edge of every (other) lower vane cover. This is the famous "tape mod", documented by Teme on his blog in 2005 and referenced on HB that allows the lower vanes to sweep the bottom of the doser clean.
Finally, get yourself something to sweep out the burr chute. I have a couple of extra hooks that look like these:
http://www.containerstore.com/shop/shel...d=10000990
that I've bent into usable shape using a bench vise and a pair of pliers. I cycle the motor and sweep out the burr chute 3-4 times, and it's pretty clean. I'll post some pics in a bit, with vid to follow.
Optionally, make a schnoz for the dispensing chute. I find that the doser likes to dump left-ish, and these tiny 49mm baskets don't give me much room for error. Careful, though. AndyS may come knocking on your door for royalty payments!
Lots of good information exists here on HB; unfortunately it has all been slanted toward Mazzers - understandably so, but the concepts apply to most other dosers. F'rinstance, Improving Mazzer Doser Efficiency
L-R: Adjustment cap, upper vanes, dispensing chute lid (detents visible), washer, lower vane cover, vane spring
Closeup of lower vane cover with velcro on the leading edge
Container Store hook, bent into submission
Vane disassembled, peering down the dispensing chute. Schnoz is visible, as are slots for fitting the detents of the dispensing chute lid
Hook in burr chute, doin' some cleaning
