One thing was particularly interested in doing was removing the part indicated in this photo, which Teme says he removed:
I reassembled the doser with this part removed, and discovered the ratcheting mechanism was still not working. At this point I assumed I'd broken something and decided to disassemble the lower portion of the doser to check. I removed the plastic cover and spring, and had a good look, but the ratcheting mechanism is not visible properly without further disassembly, so I am unclear about what it catches on.
I reassembled the bottom mechanism, slotting the return spring into the plastic cover and doser arm hole:
I then completely reassembled the upper mechanism as it was originally, with the part I removed replaced, and the return spring ratchet works fine now. With the cover part removed it doesn't work. I assume there is some friction required that is no longer present without this part, but I still have no idea how the ratchet actually operates. How was Teme able to remove the cover and have the doser work properly?
