by Ken Fox on Fri Nov 05, 2010 10:06 am
I cannot speak about your particular grinder, which I have never seen in person, however:
All grinders have recesses that collect grinds in their chambers and beans which are in the process of going from the hopper into the grind chamber. In general, these recesses fill up with grinds and beans and after this occurs the newly added and freshly ground beans will move through their respective paths without a lot of mixing. This is to say that the old stuff stays in the recesses where it fills up the voids, and the new stuff makes its way without getting very much "polluted" by the old stuff. There is another issue, the grind path itself, which I'll address below.
Some people believe that constantly disassembling their grinders and cleaning them out will assure them of fresher grinds and keep their grinders sparkling clean (inside). My view on these practices is that they waste a lot of time and risk damaging the grinders, since the burr carriers tend to be made of brass which is soft, and which often threads onto steel which is not, and this can lead to "misthreading." There are commercial grinder cleaners which can be used occasionally and which I believe do a reasonable job when it comes to maintenance type cleaning. In my own practice I do this sort of cleaning with grinder cleaners about 2x a year, usually after I have been away from home for a prolonged period during which retained grinds in the burrs could be assumed to have become quite stale, but that is just my practice. The use of the grinder itself will "clean" the burrs by forcing newly ground coffee in these spaces between the burrs themselves, which will serve to clean them.
Getting back to the grind path itself, this is where one could reasonably expect, in daily use, to accumulate older ground coffee on a shot to shot basis. This will vary by the grinder and how it is to be used. If the grinder is filled up with a certain type of coffee that is not changed shot to shot, then this aspect becomes less important than it does in the case of single shot dosing, something that I do not do personally.
In my own personal practice, where I do not change coffees in a given grinder all that frequently, I will make a point of cleaning out the grinder chute as it exits the grind chamber with a chopstick, using those grounds in the current shot. If the grinder has not been used for a number of hours, such as overnight, I will go to the additional step of grinding 2-3g of grinds through the grinder at first use for the day, cleaning out the chute, and then using those grinds to clean out the doser (assuming one's grinder has a doser). This practice of cleaning out the grinder chute with each shot, and using a few grams of grinds to clean out the doser after a number of hours of non-use will do more towards reducing admixing of different types of coffee and of stale retained coffee grinds, then will frequent disassembling and cleaning of grinder burrs and grind chambers, in my view, and has almost zero chance of doing harm to the grinder.
This topic has been discussed ad nauseum before and some searching through the grinder forum will yield a number of prior threads.
ken
What, me worry?
Alfred E. Neuman, 1955
