by JmanEspresso on Tue Dec 15, 2009 5:23 am
And, even if you are "twacking" while grinding to dose into the PF, some coffee will still have some clumps. BUT, they're not big dense coffee rocks. They'll collapse when you tamp, so you should be fine.
As for changing the burrs, its a piece of cake. Remove the adjustment collar, and lift out the top burr carrier. Each burr is held on with three screws. Unscrew the old ones, screw in the new ones. Put the top carrier(with new burr now installed) in the grinder, and thread the adjustment collar back in. Don't try and force the collar in, you could cross thread it, and THAT will not be an easy fix. But, don't worry, using plain ol' common sense, you'll be fine.
