Thatchmo wrote:Thanks Jeff.
Does your CMH have the finger guard removed? it looks like a mod I will probably do to vacuum out the grinds after a session. Can't seem to find a reason not to...
I really appreciated the CMH's dual purpose finger guard after years of brushing off grounds from every part of the Mazzer doser's "carousel" for each shot. It was a serious nuisance. By contrast, grounds exiting the CMH chute deflect off the finger guard onto the floor of the doser, where they are neatly swept up by the dosing blades.
I would not remove the finger guard, unless you are prepared to attach a substitute deflector to the doser lid as one clever poster here did.
By the way, when I said I cleaned my machine out on an annual basis, I was not including burr cleanings. I run Puly Grind or Grindz through the machine every month or so. The burrs were bright and clean when I took my CMH apart after a year. The debris I cleaned out in my annual cleaning was not in the grind path, and I would not be anal about it.
