kamali wrote:Would it be necessary to run a 1/2 pound only if i cleaned the burrs? I think you may have misunderstood and thought I replaced the burrs. Yes i believe I have it dialed in. I am using CCC Toscano, about 1 lb per week. When would the panel suggest actually replacing the burrs?
I assumed you meant what you'd written and believed you'd cleaned the burrs rather than replacing them.
You want some fresh build up on the burrs; having coffee grind the coffee makes the ground coffee taste better.
Your cleaner burrs are probably part of the reason you're adjusting them "tighter" to get the same grind. There's no gunk filling up the spaces between them anymore so you need less space between burrs to get the same grind.
The mean duty cycle for a set of Rocky burrs is around 75 pounds of coffee (h/t Dan). The generic advice is, "When in doubt, replace." It's a no-lose situation. If the new burrs don't make a huge improvement, your old ones will serve as a backup when the new ones wear out. And if they do make a huge improvement, BINGO!
Keep your eye on the grind and adjust as needed; preferably daily. If one grinder setting lasts through the week it takes to work your way through a pound of coffee, you may be one of the lucky few but more likely have some technique issues and aren't getting the most out of your beans.
How many pounds have you ground since cleaning? After you've got a couple of pounds through the machine, let's re-evaluate.
BDL
