Hi Barron,
The grinder will always "settle" in to a grind setting faster (using less coffee) if the motor is running when you do an adjustment (
especially if going finer). In an earlier post you mentioned the lower burr not dropping down when you lower the lever arms. The Vario has no mechanical means to lower the burr carrier (in an auto, the valves ride on a cam also, but they have strong return springs to lower the valve when the cam lobe drops away); we rely on the beans between the burrs to force the lower burr down. This occurs instantly when beans are in the grinder. You should not have to clean the machine to get back to a choking grind, this is not right. Are you using hard and light roasted beans? If so, this could explain the need for a finer than normal calibration to achieve a choking grind. Our calibration instructions work for the average gourmet bean, but with peabodies and other hard coffees, especially if they are light roasted, a finer calibration will be required. If you are using a dark roasted bean and having these issues, then I would suggest we (Baratza) have a look at your grinder (you appear to be somewhat "local") or we can just get you a replacement.
Sorry for the hassle so far. Please email me (
kyle@baratza.com) or
support@baratza.com and we will take care of you.
Regards,
Kyle (President, Baratza)
