AndyS wrote:1. The rate of grind varies very little with burr speed (~5g/sec regardless).
2. Increasing the burr speed results in a coarser grind.
Interesting findings. If the grind rate is invariant with speed, then the burrs have a mechanical capacity limit per unit time. As it appears that Andy's robur works better at a slower speed, one could speculate that many grinders are not configured to run at their optimal speed. It's simply cheaper to manufacture grinders with "standard" speed motors. So if you have a VFD or can change the motor/gearing, running at a lower speed may minimize noise and grind heating without reducing grind quality.
Not certain why increased burr speed produces a coarser grind. Could be reduced compressive load, mechanical inefficiencies e.g. slippage, burr chatter, size distribution, etc. As I can't think of a reason why frequent speed adjustment would be desirable, this likely isn't of practical concern but more useful for understanding how burrs work.
