I just finished reading the 33 page thread on the Titan grinders, and I had a few questions:
1. Someone mentioned thwacking the dose DURING the grinding process. I've been gently turning the doser AFTER all the grinding is done, so that coffee lands neatly in the PF. Will the former method give me better distribution? Of course, with my single dosing, the fact is that more than half of the ground coffee sits in the chute, and has to be brushed out into the doser after the grind anyway.
2. Several folks mentioned a bitterness to the MXK's shots. I have noticed a bitter finish to some of the shots but figured it was still about my technique. Is there a way to mitigate this with the MXK?
3. Once again, I read that the MXK produced better shots in the 13-14g range, lower than I typically dose these days at 15-17g. (Hairbender at 20g). Why would the lower dose produce better results?
4. Currently, my process is to single dose, then go from the doser directly to PF. My technique now is very non-interventionist at this point: I may or may not use my palm in semi-circular miovements to even out the mound, then tap the bottom of PF once or twice on the padded countertop, and then tamp. No WDT. The pours look good from my LM basket ridgeless basket. Is this what most folks are doing with this or other large dosered grinders? Are some of you dosing into the basket first, and then putting it in the PF?
PS I've moved the discussion to
Titan Grinder Project since it pertains to the Titan thread.
