Ah.... So I'm not senile yet. That's good news. Maybe I can let myself go over lunch today after
Well a trip to Liverpool might be a laugh - assume Eric is of the same opinion.
Otherwise.... who's local?
Is your Elektra happy again?
michaelbenis wrote:Jon's suggestion of dosing a bit more and dumping the first bit would skew the results in favour of the single-shot shots because they would be getting a longer grind than in true single-shot use.
michaelbenis wrote:Ah.... So I'm not senile yet.
JonR10 wrote:So my suggestion is to charge a single and grind through, and then add your weighed dose and use the grinds from that for the shot (assuming the grinds retention of the Nino is less than a single shot). In other words, you would need to start by grinding through an amount greater than the amount of grinds retained in the grinder between shots, and then grind your measured dose.
JonR10 wrote:No, not at all.
It seems to me that could favor one method over the other and skew the result.
Choosing the dose arbitrarily and then comparing how the two methods taste seems a better test. Both types would then be on equal, neutral, non-optimized footing.
RapidCoffee wrote:Many good ways to do this, and all could provide useful data points.
cafeIKE wrote:Forgive me and don't take offense, but why bother?
JonR10 wrote:Merry Christmas Mike!
Maybe we envision it differently. For example, when I grind 3 doses in a row I do not load them together. I start the grinder and drop in the first dose.....then after a few seconds I drop in the second dose (and so on). If I put in 3 doses together then the grind comes out too tight.
This would allow you to test freshly ground coffee each time as opposed to what has been retained in the grinder between shots. When we do it here I am going to sweep the grounds from the chute of the Robur-E and manually control the dose for much the same reason.
Does that make sense?
shadowfax wrote:+1. I think the only dead set rules for a good test are that you be completely transparent about methodology and that you apply it consistently.
michaelbenis wrote:Being a selfish beast I would of course like to conduct the test at the dose/s I use most frequently, but I am also very curious to see what happens at the higher doses favoured across the pond.
