. . . to create a makeshift hopper:
The funnel base at 2 1/4 inches in diameter is slightly loose, so I put the rubber band around the base as a washer and got a perfectly snug fit. The funnel sells for $7.99 at Amazon http://www.amazon.com/gp/product/B00004UE88
The 5 inch black top from the Bodum storage jar matches the Macap's black trim, and the plastic insulation on the underside of the lid (for making the jar airtight) helps secure the top over beans while they are grinding.
I've attached a favorite cleaner here at the end of this tip, which has probably been discovered by lots of you, but it works too well to overlook. The concentrated form of Citra-Solv will soak through and clean the most gunked up screen in a minute or less. The concentrate is so strong, make sure to wash your hands thoroughly after using it or it will burn skin.
