snaab wrote:I have been using Rocky many times/day now for just over a year and while have had no issues, I figure it's probably time for a cleaning or past time for a cleaning. Not being the most mechanically gifted guy on the block, hoping that one of you folks might have a few easy-to-follow instructions that even i could understand.
While commercially available grind-y cleaners (and some over-the-counter home remedies) will probably suffice, it isn't a bad idea to be somewhat familiar with the guts of your gear. That way, you get to replace your own burrs if you chinger one on a rock or something, or you drop the stone off your ring into the grind chamber (don't ask).
There is a fairly detailed description that
Mark Prince does that's pretty darned good, but if you just remove the hopper and upper burr by unscrewing it all the way off, you can get to the most important bits.
