PreambleThis will, most likely be my final post on this thread (hold your applause), unless prompted. I seem to be bumping myself, not a good sign.
I hope I've been, in some small way helpful, and I've tried to be as even handed as possible.
On to the (final) business at hand. As I started this thread more as a "pat on my back" for fine-tuning my friend Pete's Vario, (I am decidedly not mechanically inclined) and not as a "Should I buy one?" thread, I'll comment on the "should I buy one?" now.
First, ask yourself (I did), would I actually use the Vario as a multi-purpose grinder? Switching coffee's using the Vario is old school, turn the grinder upside down and gently pat the bottom till all the present bean has been removed.
Grind to purge remnants. Add your "breakfast coffee" whether it be drip, vac/French press and have at it.
As I do recommend the hopper be filled at least 1/4 of the way, as opposed to dosing the grinder per shot, this would be/has been my procedure. Of course, one could just finish what's in the grinder, heck what's a few extra shots before bedtime?
Not a biggie to me. I have done the dump and fill, and it's all good, as every bean exits, and a quick on/off only spits out about 2 gram at most.
So YES, if I owned a Vario I would use it as a multi-purpose grinder, as I've found the vac grind to be superior to the Maestro and equal to my former SJ (as memory serves), and better at French Press than either. Switching back and forth only wasted maybe 3-4 grams, and that only occurs when going coarse to fine. My experience with Baratza CS (re-my Maestro) was pleasant and prompt, and I believe this certainly would extend to their new flagship, the Vario.
I've elucidated earlier as to my likes and "not-so-likes." No grinder is perfect, but the Vario, at least for me requires less "work-arounds," maintenance, and is certainly less wasteful than many of the usual large heavy metal cast of characters. Sure, there is something about a 30# grinder with decades of excellence that inspires confidence, no getting around that. And yes, there are other grinders, including the Mazzer SJ that can go from an espresso grind to a drip grind just as easily, though occasionally, getting back to the original espresso setting is a bit of guess work. I also found that the wonderful espresso grind from my SJ exceeded the quality of the SJ's
drip grind, as the SJ is meant to be an ESPRESSO GRINDER. Again, I mean this NOT as a put down of the SJ, but only as a means of comparison. The SJ is in a class of it's own for workmanship, grind quality and build quality.
However, IMO the Baratza/Ditting Vario's simple, yet precise electronics and GRINDING capabilities, compact size, ergonomics, and quiet operation make it an excellent choice for a centerpiece, all inclusive grinder for the home.
BTW, I like the blue light, what's the big deal?
