nixter wrote:So far so good with the Vario. I'm very happy that the upgrade has been tangible. Shots are far more consistent and I'm tasting things I never could before. I really like the timed grind feature. I also like the fact that there's very little waste. You pretty much get out what you put in. Very little clumping or static if any. I haven't found the PF fork very usefull with my naked PF but grinding into the bucket and pouring into the PF is fine. It also allows me to shake the grinds first, completely loosing the odd clump, before pouring them into the PF. Other pluses are the quite operation and the very small footprint.
If you do French Press at please, please grind for same, and do a quick report. Lots of folks considering the Vario are wanting this info.
Glad you're happy. I'm enjoying my "loaned" Vario, even though it is 1st generation. Quiet rumble is nice, and the timer makes it easy, once you determine the load weight at your setting.
I'm getting 14.2 grams at 12 seconds.
Of course this will vary according to fineness, and the type of coffee in the hopper, the weather, the position of the moon on Thursday, etc
