actionhost wrote:Is it true that one gets better grind when the hopper is (half) filled rather then a little amount beans for a single dose?
None of the fairly frequent taste tests has shown a difference in taste. But ...
Many like the appearance of the grinds from a filled hopper more, claiming it is fluffier and easier to pack. Many find the grind adjustments easier with a filled hopper. Filled hoppers always require coarser grind settings than single shot dosing, and have significantly faster grind times. My guess is that these ergonomic improvements subliminally affects people's taste judgments.
The ergonomic improvements alone mean that if you are using the same coffee at the same dose repeatedly, it is mostly preferable to use a filled hopper. Single dosing is for those frequently changing blends or grind settings between shots
