sweaner wrote:Has anyone found a way to use the Vario without the hopper in place, like I do with my Mazzer? I use a small stainless funnel and a tamper for weight, finding this easier for grinding by the dose.
WHY, with a timer would you want to do this?
This question reminds me of folks who have been analog music engineers and such, when entering the digital recording realm try applying the same techniques. Uh uh.
There is NO need to work in that manner (by the dose. This grinder works MUCH better when the hopper is 1/2 filled.
It's a matter of getting used to the fineness setting/timer ratio, which will determine how much you get. You can also just pulse the grinder to add additional grind.
Of course, as you change coffees and roast degrees, things will change, but usually a shot or 2 and you're good to go.
A 1 second purge, if you haven't ground for a while is always good.
This grinder wastes little, when used properly.
To the OP fiddle farting with the safety switch, why?
Just use compressed air to dislodge any grind.
