I keep my Vario pretty much dialed in for espresso. I'll experiment with the micro arm, but the macro pretty much stays put. When I make the occasional cup of Aeropress, I maintain the fine grind and just adjust the rest of the process accordingly. However, one (memorable) time I did adjust the macro arm in order to judge its performance with a press pot. After adjusting it back to it's usual espresso setting (grinder running & empty), I then noticed a significant static problem. Rather than the grounds landing in the portafilter in a nice neat mound, they sprayed out everywhere and made a huge mess on the counter. That persisted several days, even after disassembling & brushing/vacuuming it out. After a few more days, it randomly started to behave again. I chalked it up to bad karma and proceeded to forget about it.
The other day I adjusted the macro arm in order to make copious amounts of Aeropress, and after returning it to the espresso setting the symptom has again returned. This has officially become a pattern. Has anyone else's Vario done this, or is it just my copy?
