IMAWriter wrote:Did you not have the PF attachment for the Vario?
Yes we did have the portafilter holder in place (very positive locking mechanism, no chance of falling out by mistake). I think that part of the problem is that the sides of the grinder body come almost flush with the trailing edge of the filter basket (part closest to you). This means that you can only 'swing' the portafilter handle somewhere between 90 and 120 degrees, certainly less than 180. The Mini allows more like 180. I don't think that this is a function of the basket size. If it has a handle, it can only swing so far.
I don't quite understand or like the explanation of leaving the portafilter adapter partially leaning out? It is well designed to fit and smartly snap into place. Also, my problem was that it dumped most of the coffee at the 3 o'clock position, not the 6 o'clock position. So how would leaving the contraption partially installed help that?
It's only my humble opinion, but it seems like an awful lot of money for a grinder that requires so much tweaking, and compensating for stuff. Your grinder is the heart of the system. It needs to be as reproducible and robust as possible. I have not checked on the price difference between the Vario and the Mini, but just the build quality alone puts them in two totally different categories. My guess is that the Mini would outlast four or five of these grinders. My guess is that the Vario would not hold up very long in a commercial setting, yet we know that the Mini does.
Like I said, the Vario is very sexy looking, and it is no comparison to my Solis Maestro, however, it is no Mazzer Mini. My first grinder was the Solis Maestro. Very nice for drip and press grinds, but unacceptable for espresso (my intended use). I felt that I had wasted about $125 since I still needed a grinder. Talking with the vendor, he explained that the Mini was no comparison. He told me that my biggest concern would be that it would out live me and that I would need to decide whom to leave it to in my will. If you are much younger than me, and it eventually seizes the motor, you will still have a decent boat anchor.
I have since moved on to a Mazzer Super Jolly that was cleaned up and repainted after it's first life in a Starbucks (before they went to the super automatics). It is still flawless after it's early years of abuse and neglect. I still use my Mini with my backup machine and it is of similar quality and build, the primary difference is the rate of coffee ground per unit of time. My point is that if you are going to pay that much for a Vario, I think that you should give serious consideration to the Mini and get used to counting in your head while you grind so that you know when to turn it off.
I don't own stock or anything in Mazzer, but after more than 5 years of daily use I can see no difference in performance of my grinders. By now I thought that I would at least have had to change the on/off switches. So far so good.
Good luck with your choice,
