Hi all,
My 2 year old Ascaso iMini (used for one or two cups a day) has recently started changing the grind slightly itself whilst grinding! The change isn't much, but I can clearly see the adjustment wheel at the side rotating a few degrees.
I flipped the lid off today to give it a quick clean (which I do fairly regularly anyway) and see if I could tighten anything but looking at the insides it appears that the circular wheel that sits on top of the burrs is actually moving slightly.
I have never replaced the burrs as I don't use it that extensively (I did anticipate its probably on the cards soon but not quite yet). I also don't adjust the grind widely , just quarter / half a turn here or there as the coffee dictates. However the last coffee I had was a stubborn one which meant I had to turn the wheel 2 complete turns to coarsen the grind, which is the most I have adjusted it since I bought it. I only noticed the problem the last few days.
If anybody knows this grinder well and has experienced this problem id love to hear from you, sending it to Ascaso for repair is an expense I could do without right now (as well as not being able to grind for a few weeks - nightmare!)
