Any new Mazzer Super Jolly doserless designs???
Postby zubinpatrick on Wed May 11, 2011 5:58 am
Going to do mine soon. Checked out archives...nothing awesome yet....hmmm just had an idea. I was hoping to put a push button on the porta hanger so a little pressure and it grinds....also why do all the home mods have such a huge collector....is there any reason a small one wouldn't work?
zubinpatrick
Postby ZDUNK31 on Fri Jul 15, 2011 4:52 pm
Did you do your mod ? Curious, as I am considering the same.
ZDUNK31
Postby Euology101 on Fri Jul 15, 2011 10:43 pm
Why not do the Doserless mod like this (this is a Mazzer mini, you can do the same thing with the SJ, just one different part) : Image
I'm getting an SJ next week, and plan on swapping the mod to the SJ, and put it on a darkroom timer. Can't ask for much more.
-Justin
Euology101
Postby ZDUNK31 on Sat Jul 16, 2011 9:47 am
Where did you purchase the parts from for your mod ? The funnel, lid, and gasket are easily found, but I can't seem to find the back cover anywhere. Also, have you seen the SJ burr swap for the mini ?
ZDUNK31
Postby Euology101 on Sat Jul 16, 2011 11:27 am
ZDUNK31 wrote:Where did you purchase the parts from for your mod ? The funnel, lid, and gasket are easily found, but I can't seem to find the back cover anywhere. Also, have you seen the SJ burr swap for the mini ?
http://www.espressoparts.com/cgi-bin/ep..._id=813565
This is the backing plate for the SJ. I have seen the SJ burr swap, but it requires modification for the Mini Carriers as only the Mini-E carriers are sized for the 64mm burrs. I'm working on getting an SJ and selling the Mini.
Euology101
Postby Bobmac on Sat Jul 16, 2011 1:21 pm
I mod'd my Super Jolly with the Espressoparts gear. It was easy and works and looks great. Well worth doing.
Bobmac
Postby pizzaman383 on Sat Jul 16, 2011 1:30 pm
It's not a Super Jolly but here goes. I just got a Fiorenzato Doge 83 for a very good price and after one day I knew I hated the doser. I had seen a picture of a funnel mounted inside a doser so I did it this morning.
It's kind of cludgey but it was free and all the bits are hidden inside the doser (the cap still fits on). I'll probably eventually buy the Super Jolly doserless funnel but this will do for a while.
Curtis
pizzaman383
Postby ZDUNK31 on Tue Jul 19, 2011 6:34 pm
Thanks for the replies, I definitely plan on doing the mod in the future.
Was also thinking about the timer switch, and am looking at trying to wire in a timer circuit and replace the dial switch with an off/on switch.
ZDUNK31
Postby Euology101 on Tue Jul 19, 2011 7:03 pm
ZDUNK31 wrote:Thanks for the replies, I definitely plan on doing the mod in the future.
Do a search for Delta Timers, seems like a slowly merging mod for the larger Grinders. I think it is probably one of the better mods, it's by far the most precise, and if done right, it can be non-evasive, to where if you upgrade you can keep the mod for the next titan grinder.
Euology101
Postby espressotime on Wed Jul 20, 2011 6:44 am
I did the SJ doserless mod an I have to say it sucks big time.
http://i143.photobucket.com/albums/r156...004-45.jpg
Due to static problems(which an original grid didn't solve one bit) it makes a mess.
I built it back to hopper after a few days.The doserless kit has been in the box since I rebuilt it back to it's original state.
espressotime
Next
Return to Grinders
