2014 HG one grinder - Page 38
It is a good questions, why do robur have two different types of burrs?
- weebit_nutty
True.. The bead blasted ones I imagine to be frustratingly difficult with light roasts, given even with my TiN coated burrs, the machine has buckled on me a few times.. At 83mm, I don't think anyone in their right mind would want anything other than TiN coated burrs.FotonDrv wrote:One is easier to crank.
- FotonDrv
Different coatings AND different diameters. 71mm and 83mm depending on voltage of the grinder I believe. Someone please correct me if that voltage thing is incorrect.jagobear wrote:It is a good questions, why do robur have two different types of burrs?
Yes, the 71mm set is used in the single phase spec, and the 83mm burrs in the 3 phase spec Robur.....it's a more powerful machine.
- TomC
FotonDrv wrote:Different coatings AND different diameters. 71mm and 83mm depending on voltage of the grinder I believe. Someone please correct me if that voltage thing is incorrect.
You got it right, 83mm is 3 phase 220v, 71 is single phase 110v.
The voltage is not the deciding factor.
For instance, in Europe, UK, Australia, etc,...single phase is 220-250 volts and 3 phase is 420-440 volts.
Obviously Mazzer and others fit motors to suit the local voltage, so the Aussie single phase Robur will be 220-240 volt but still 71mm burr set.
The big change with 3 phase motors is the higher starting torque.
That sounds like the absolute last thing a company would want. Better to just pick one to sell so everyone will stop talking about which option is more fantasticweebit_nutty wrote:Ultimately it resulted in an endless stream of posts debating or extolling the virtues of each burr design..
- FotonDrv
I have both the 71mm and the 83mm burr sets for the HG-One and the only real obvious difference I could tell was the 71mm burrs took less effort to crank.
I never did try a TiN 71mm burr in the grinder but I would suspect the cranking effort would be much less than the 71mm BB burrs.
Interesting info about Australia. 440v for 3 phase and 240v for single phase. Can you get a 440v Robur?
Whilst I have never personally seen one, there are discussions about cafe's with 3 phase Roburs installed at great expense as really this is "industrial" class electrical equipment.
I suspect these will become even more rare as compact inverter drive systems are now available that can replicate the multi phase (3ph, 6ph, or more) supply for high torque , multi phase, motor designs.
Even small kitchen and garden equipment is now powered this way ( "Brushless" motors)
- FotonDrv
I have been using one of those drives on my table saw for 30 years and it has never given any trouble, nor has the saw motor!
