edwa wrote:Writers on this thread have touched upon the popcorning issue a couple of times. On other posts, pictures show people using a variety of items in the tops of their Mazzers and Macaps like tampers, plumbing parts, etc. I've also read from Ken that he keeps a certain amount of beans in the hopper, I think it was something like at least 3 shots worth?
The question is what are the rest of you Cimbali owners doing?
cannonfodder wrote:I don't think it is as big of a deal as I once perceived it to be. For me, the key is consistency. If you grid per shot, then always grind per shot and your grind will be consistent. If you put 30 grams of coffee in the hopper, than always put 30 grams of coffee in the hopper and the grind will be consistent.
Now if you put a half pound in there and set the grind, the last two shots will run noticeable fast as the grind shifts. I keep my grinder hopper full to just above the burr throat. That is around 3 shots worth of coffee. I grind make my shot and add a little back to keep the level the same.
jmcphail wrote:I think the Max/Hybrid works best with beans in the hopper, I think it's just designed that way, and it fits my usage pattern. Switching blends a lot would get old though, I don't think the hopper and throat design are as amenable to switching as other grinders are.
Marshall wrote:At the risk of offending some, I have to point out once again that the online coffee forums are a great breeding ground of obsessive compulsive coffee behavior.
Beans will not go bad sitting in the hopper for two or three days. Besides, repeatedly opening and closing sealed containers introduces plenty of oxygen into the container anyway. Popcorning is real. The last grind or two, if you let the hopper empty out, will nearly always be inferior (though drinkable) to grinds with a column of beans on top. Plus the grind takes much, much longer, if you are doing one shot at a time.
There is no, repeat NO reason to put one shot at a time into an espresso grinder, unless you are a professional cupper, sampling several different coffees in a row (in which case you should be using a different grinder). [EDITED]
Cafesp wrote:
- Coffee residual left in the chute mouth, behind the small plastic safeguard inside the doser! ( your choice to use a short brush to get it out or to cut the safeguard plastic off ..
Cafesp wrote:The small plastic inside CMH doser is just a finger safeguard or has any function in de-clumping or even distribution?
zin1953 wrote:Presented in the FWIW Dept. . . . I remain extremely pleased with my Cimbali Max Hybrid grinder, and would recommend it without hesitation.
And that, bottom line, is what it's all about.![]()
Cheers,
Jason
Marshall wrote:It has the additional, possibly unintentional, function of deflecting grounds away from the axle and top of the rotating "carousel." This was a welcome change from the Mazzer, where I was brushing grounds off the mechanism all the time.
