As documented elsewhere, I upgraded from a Gaggia Carezza and MDF to a Vibiemme Domobar Super (Manual, black) and La Cimbali Max Hybrid. The difference is....almost indescribable. Leaving taste aside for the moment, these new machines are light years ahead in terms of design asthetic and, more importantly, ease of use. I am absolutely glad that I spent 3 months cutting my teeth with the Carezza, as the basic skills are obviously transferable and I knew off the bat what I needed to do and what results I wanted to see. The first shot from the new combo was - while far from perfect - better than anything I've pulled to date. The nagging bitterness that I'd never been able to eliminate on the Carezza was gone. My taste is telling me that I'm still brewing too hot, though, so I've got a lot of tasting and trial and error ahead.
First thoughts, impressions, and also a question.
Questions:
Question: the VBM's brew pressure never gets above 6 bar, even if I'm using the blind basket to backflush. My assumption is that I need to open the machine and increase the brew pressure, but never having owned a machine like this, I'm a bit lost - Dave's review suggests that I'd do this at the OPV near the resevoir, and the owner's manual shows a picture of what to look for. Am I on the right track? I have an email in to 1st Line but would appreciate hearing from the community here, too.
Question 2: when backflushing (something else I've never done, since Carezza didn't have the capability), I thought the water would come out into the drip tray, but that isn't happening (until I end the backflush). Am I missing something, or is this normal?
Impressions:
Max Hybrid: Wow. Mine arrived set to 5.5 on the dial. I dialed it to 5 before grinding the first time. It takes only around 10 seconds to grind enough coffee to fill the PF - a huge change from the 25+ seconds for the MDF. The grinds come out of the doser looking near perfect; they are fluffy with no clumps. Level, tamp, and I get a perfect puck, and one that doesn't show any evidence of channeling after the shot (no tell-tale pinholes). At 4.5 I only get a trickle from the machine, and at 4.75 I'm getting less than ristretto volume. The 5 setting is pulling close to 1.5 oz in 30...but these shots run longer before blonding. I think all of this will change when I fix the brew pressure on the VBM.
VBM: Man, I love the look of this machine. Set up is easy and, with the three way power switch, first time power-up is worry free. It's got the flow restrictor in the HX thermosyphon that Dave mentions in his review, so I see very little if any flash boiling when flushing water. My current routine (suggested by Dave) is flush about 4 oz of water when the machine's been idle, then prep the PF, flush a bit more, and go. The shots look great when they are pouring - none of the blackness that would characterize the start of my Carezza pulls - and look great in the cup (no more light crema). Taste is great, but I know it can be better. I need to sit and experiment with flush amounts to get the shot temp a little lower.
As for steaming, this thing is a monster! It takes no time to steam; gone are the days of steaming 6 ounces for nearly a minute and running out of steam before the temp hits 155. On the flip side, the first time I steamed milk, I started with 6 oz in a 12 oz pitcher, and the milk overflowed the pitcher before the temp got to 150!!! The consistency of that milk was really nice, though. I've gotten closer to microfoam but I'm not there yet. I have to figure out how to stop the stretching of the milk so that the volume doesn't get out of control like something from a cartoon.
Overall, incredibly happy with this kit. Thanks for all your help.
