www.eccocaffe.com: custom coffee roasted in Northern Italian style
Woot! Vibiemme Domobar Super & Cimbali Max Hybrid have arrived - first impressions and questions - Page 2
Link to "Woot! Vibiemme Domobar Super & Cimbali Max Hybrid have arrived - first impressions and questions"by Bex on Fri Mar 14, 2008 10:46 pm
Wahoo! I made microfoam tonight! Hurrah!
I really, really heart this machine. Not to mention the many videos available here to allow me to learn so quickly.
Bex
Link to "Woot! Vibiemme Domobar Super & Cimbali Max Hybrid have arrived - first impressions and questions"by Fore on Sat Mar 15, 2008 3:01 pm
Boy Bex, what a rough start! Esp coming from someone without a lot of experiences messing with some of the nuances of more complex machines. I hope you get that spring easily replaced and it does the trick.
Good Luck!
Fore
Link to "Woot! Vibiemme Domobar Super & Cimbali Max Hybrid have arrived - first impressions and questions"by Bex on Mon Mar 17, 2008 10:33 am
It hasn't been too rough - the machine combo is pretty noob-proof. :)
The main impact of the wandering brew pressure is that the pulls vary between ristrettos, normales and lungos whether I want them to or not. :evil: Yesterday a pull hit 10 bar and gave a lot of volume; this morning the pulls were closer to 6 bar and not a lot of volume. Stopped each pull when they were blonding, and each tasted fine (to my pedestrian palate).
Edit: and the new spring from 1st-line just arrived! I will try to install it tonight. I still have some trepidation about that part, but what can you do. :)
Bex
Link to "Woot! Vibiemme Domobar Super & Cimbali Max Hybrid have arrived - first impressions and questions"by Bex on Mon Mar 17, 2008 9:10 pm
Surgery complete. The patient is heating up.
Like Randy's post in the VBM buyers guide, the spring in my machine was thinner and springy-er, the replacement thicker and stiffer. It was a chore to unscrew the OPV with the old screw inside. Had to remove the panel that separates the boiler from the reservoir (and which also supports the reservoir). Even after that, it was hard to turn the screw. Once the new spring was installed, the OPV screw turned easily.
Plugged it in and started dialing in the brew pressure. No wild fluctuations this time; just a simple process of turning the screw until I found the point I wanted (going with 9.75 to start, since Jim says the pressure at the puck is about 1 bar less than the pressure shown on the gauge).
I am a bit freaked out at the moment - worried that I may have inadvertently damaged something without knowing it. I heard something rattle in the case when I first rotated it to open the OPV, but I couldn't see anything loose, and never heard the sound again. All appears to be working. In a few minutes, it will be ready to pull shots and we'll see how it goes. :)
Bex
Link to "Woot! Vibiemme Domobar Super & Cimbali Max Hybrid have arrived - first impressions and questions"by cannonfodder on Mon Mar 17, 2008 9:55 pm
I think you will find your results much more satisfying with the new OPV. Please post back your results.
cannonfodder
Link to "Woot! Vibiemme Domobar Super & Cimbali Max Hybrid have arrived - first impressions and questions"by cafeIKE on Mon Mar 17, 2008 11:11 pm
Bex wrote:I am a bit freaked out at the moment - worried that I may have inadvertently damaged something without knowing it. I heard something rattle in the case when I first rotated it to open the OPV, but I couldn't see anything loose, and never heard the sound again.
If you just undid the OPV and replaced the spring, there is not much chance of any damage. It's always a good idea to run the machine with the side cover removed after any 'surgery' just to make sure there is nothing amiss.
cafeIKE
Link to "Woot! Vibiemme Domobar Super & Cimbali Max Hybrid have arrived - first impressions and questions"by Bex on Tue Mar 18, 2008 9:44 am
I'll probably panic at any odd noise it makes for the next week. 8)
But the brew pressure issues are done! The machine is nailing the brew pressure every time now - no variation - so I can focus on dialing in the grind.
Thanks everyone for your help & to 1st-line for getting the spring out to me so quickly.
Bex
Link to "Woot! Vibiemme Domobar Super & Cimbali Max Hybrid have arrived - first impressions and questions"by Bex on Tue Mar 18, 2008 9:12 pm
Now that the brew pressure is a rock solid 9.75, it was time for the fun to really begin.
I have read so many posts here where people talk about varying the dose and achieving different flavor profiles, but have never had the machines to try it myself. That's changed. My typical routine for the past week, while waiting for the new OPV spring, has been to grind into the PF, sweep my fingers over the top, tamp, and pull the shot. It is not, I confess, in my nature to buy a scale to see what that dosage weighs, but I suspect it's underdosed, as there is never any visible indentation from the screw left behind on the puck.
Tonight, I decided to play with upping the dose. The first attempt, instead of sweeping my fingers over the top, I tried to compact it all into the PF. It was a tighter fit to lock in the PF, and I expected disaster. I got it. Choked the machine, and there was a serious impression left on the puck by the screw. (Note to the horrified onlooker - this is how I prefer to learn and to cook, by look, feel, and eye rather than by precise measurement, modifying the routine to suit my taste, and as you might suspect, I am no baker.) On the second attempt, I did not have as much coffee in the PF - it was still over the top of the PF, but not by as much (more like a "heaping PF" full). I compressed the grounds with my finger, tamped, and locked in (no unusual resistance). The shot pulled normally. And my lord, what a difference in the taste. It was completely different than the normal shot. I caught a few fruity notes, which surprised me.
This is serious fun. I am now looking forward to all the variations I can try with this machine.
As to microfoam, I haven't duplicated the epiphany moment mentioned above. I am getting close, though. Right now my pitchers end up with a thicker consistency foam on the top, and then the expected consistency through the rest of it. Got to figure out this bit so that I can eliminate that overly thick stuff (I want to try latte art rather than pour a traditional cappa), but I'm learning.
In the minor annoyance department, I have experienced two of the issues Randy noted in the bench thread - water does get behind the drip tray (very minor issue), and the drip screen is coming loose on the cover of my drip tray. The latter is more of an issue because my heavier cappa cups (NP tulip) cause the screen to bend into the tray and then they begin to slide away. I fixed this temporarily with electrical tape, and will likely use some CA glue soon to see if that's a more permanent solution.
Bex
Link to "Woot! Vibiemme Domobar Super & Cimbali Max Hybrid have arrived - first impressions and questions"by Beezer on Tue Mar 18, 2008 9:37 pm
Glad to hear you seem to have solved your brew pressure problem. As you say, now the real fun begins. Getting the dose just right is a bit tedious, but once you get it dialed in, you should be able to get great results pretty much every time.
With regard to getting good microfoam, have you seen this thread yet?
how-to-steam-milk-for-cappuccinos-and-lattes-t5258.html
There's a video there that Cannonfodder made of steaming with the VBM. You might want to mimick his technique and see if that works for you.
"There are no stupid questions, only stupid people."
Beezer
Link to "Woot! Vibiemme Domobar Super & Cimbali Max Hybrid have arrived - first impressions and questions"by cafeIKE on Tue Mar 18, 2008 10:36 pm
Bex wrote:In the minor annoyance department, I have experienced two of the issues Randy noted in the bench thread - water does get behind the drip tray (very minor issue), and the drip screen is coming loose on the cover of my drip tray. The latter is more of an issue because my heavier cappa cups (NP tulip) cause the screen to bend into the tray and then they begin to slide away. I fixed this temporarily with electrical tape, and will likely use some CA glue soon to see if that's a more permanent solution.
Put a very thin sponge under the drip tray. Soaks up all the water.
The drip tray screen was a problem with the first iteration. Should be a warranty replacement.
cafeIKE
Link to "Woot! Vibiemme Domobar Super & Cimbali Max Hybrid have arrived - first impressions and questions"by Randy G. on Wed Mar 19, 2008 1:10 am
Bex wrote:I'll probably panic at any odd noise it makes for the next week.
I think the rattling sound might have been the water reservoir platform moving around. Or possibly the little plastic cover over the pressurestat adjustment access hole.
The old spring was hard to get out because I think they use a silicone grease on the threads that tends to thicken a bit.
your results from changing the spring as indicated by the brew pressure and no puddles does indeed indicate that you did the job correctly.
And don't worry-- that machine is really tough... and relatively easy to repair. :wink:
Espresso! My Espresso!
Randy G.
Link to "Woot! Vibiemme Domobar Super & Cimbali Max Hybrid have arrived - first impressions and questions"by Bex on Wed Mar 19, 2008 8:52 am
Beezer wrote:Glad to hear you seem to have solved your brew pressure problem. As you say, now the real fun begins. Getting the dose just right is a bit tedious, but once you get it dialed in, you should be able to get great results pretty much every time.
Indeed, that is the technique I am using. I think my issue right now is that I'm stretching it too much. I only steam 5 or so oz of milk each time (in a 12 oz pitcher). I'm sure I'll get the hang of it eventually.
I experimented with dosage more this morning. Really enjoying the larger dose, but I need to play a bit with the grind setting now. I think it needs a slightly coarser setting with the larger dose.
Contacted Jim about the drip screen and we'll see what he says to do with it. My sense is that CA will hold it for a while, but it does tend to get a little brittle, so it's not permanent.
Randy, no puddles and everything seems to be okay, so I am feeling good about the repair now. :)
Bex
Link to "Woot! Vibiemme Domobar Super & Cimbali Max Hybrid have arrived - first impressions and questions"by Bex on Wed Mar 19, 2008 9:57 am
More raves for 1st-line - they are getting me a new screen for the drip tray.
I have to say that overall I am ecstatic with these two machines and the vendors.
Bex
Link to "Woot! Vibiemme Domobar Super & Cimbali Max Hybrid have arrived - first impressions and questions"by cannonfodder on Wed Mar 19, 2008 11:53 am
I am still puzzled by the water behind the drip tray. I have been using one for 6 months and not had this issue. The only water I get under the drip tray is what falls from the drip tray cover when I remove the drip tray to empty. Do you have the drip tray on correctly, there is a front and back. If you get it on backwards, the drip tray will not close completely and leave a little gap between the back of the tray and front of the machine that water could splash between.
cannonfodder
Link to "Woot! Vibiemme Domobar Super & Cimbali Max Hybrid have arrived - first impressions and questions"by Bex on Wed Mar 19, 2008 12:02 pm
It is on correctly - the notches are on the back side. However, it does not slide flush into the back panel, so that may be the cause. The amount of water behind the drip tray after a morning's use is very small - a puddle maybe the size of 2-3 quarters.
I'll report back on this issue when I get the new cover.
Bex
Link to "Woot! Vibiemme Domobar Super & Cimbali Max Hybrid have arrived - first impressions and questions"by Bex on Thu Mar 20, 2008 11:52 am
Mmmm.
(Actually, this one ended up pulling a little hot.)
Bex
Link to "Woot! Vibiemme Domobar Super & Cimbali Max Hybrid have arrived - first impressions and questions"by cannonfodder on Thu Mar 20, 2008 11:53 pm
Looks good, very good. What blend are you using?
cannonfodder
Link to "Woot! Vibiemme Domobar Super & Cimbali Max Hybrid have arrived - first impressions and questions"by Bex on Fri Mar 21, 2008 7:40 am
That one is CCC's Espresso Aficianado, good stuff.
Bex
Link to "Woot! Vibiemme Domobar Super & Cimbali Max Hybrid have arrived - first impressions and questions"by Bex on Tue Apr 29, 2008 12:43 pm
I just wanted to update this now that I've had the machines for a while.
The joy is still there. My favorite thing, I think, is the overall ease of use. At this point, if the machine has idled more than 30 mins, I flush a cappa cup full of water (roughly 5.5 ounce NP cup). If it has been idle for less, I flush roughly 3 ounces. Less than 10 minutes is just a short flush. The results are incredible. My palate is growing day by day as I learn to appreciate different coffees - CCC's new Biloya just arrived and I am looking forward to trying it tomorrow.
I am starting to get latte art results. Nothing great or worthy to post, but little hearts, tulips, and today even a sad little rosette.
I know it's popular to say that the barista is the most important part of the MMMM equation, but honestly I don't think I'm very good at all - these machines cover a massive amount of flaws.
Bex
Link to "Woot! Vibiemme Domobar Super & Cimbali Max Hybrid have arrived - first impressions and questions"by zin1953 on Tue Apr 29, 2008 5:58 pm
Congrats -- glad to hear everything is going well and living up to expectations!
zin1953
PreviousNext
Return to Espresso Machines
