jmatt wrote:Thanks for the responses all. Some new things to think about.
I've wondered about the whole cooling flush, temperature regulation rigamarole with the E61. However, since I'm only usually preparing two drinks at a time, I figured it wouldn't be so bad. I can see how it would get old with larger volume production.
Thanks again.
After 3 1/2 years, I just sold my Isomac Tea, a "solid" E61 machine, and I've got a LaSpaziale V-2 on order from Chris Coffee. It's not relevant that what finally motivated to give into my upgrade itch was that the Tea had a problem I couldn't figure out easily (that can happen to me with any machine). So it was a good time to make a move.
Some observations:
Don't assume that your current use or "need," or your mean # of shots per week should determine the machine you buy, and don't assume that you are correctly anticipating your number of shots. For example, my wife and I each have a cappa in the morning, and then I have another shot before taking off. PM, it's another decaf cappa each. So that's a minimum of 5 shots, often more and it means that I refill the reservoir daily at least.
There may be occasions (once a month? twice a year?) when you want multiple milk shots for guests who are lined up. Likewise, frequency of use doesn't necessarily translate into a sensible decision because ANY of the machines mentioned in this thread are "good enough." You don't necessarily buy your car on the basis of how many miles you put on it each year, but how you like to feel when you drive. And don't feel that because you are a "beginner," you should be looking for a "beginner machine."
FWIW, a direct connect machine saves lots of annoyance on a number of counts (including, in my case, dribbling water into the innards of the machine when filling it, running out of water in the middle of a shot, and more). Some reservoir machines have an option for direct connect and that's worth considering. If you can work out the access (not drilling through granite or draping a hose across the kitchen) the plumbing itself is, literally, a snap.
Be sure to check out your needs for filtering and softening, and make that part of your decision-making.
Consider buying from either of the two "gold standard" (IMO) Internet dealers----Chris Coffee, or 1st Line. If neither carries a machine that seems right, consider another machine. Not to disparage other machines and dealers, some are truly outstanding, but as an espresso newbie, you want to play the best odds.
Martin
