The wisdom of purchasing a used grinder from eBay
Link to "The wisdom of purchasing a used grinder from eBay"by CaptPat on Sun Nov 04, 2007 9:14 am
I just purchased my first prosumer espresso machine (a used ISOMAC Rituale), using a Rocky grinder to share both coffee and espresso grinding duties. I want to purchase a dedicated espresso grinder that I can leave set up for espresso grinding. The used Mazzer Super Jolly's on eBay look like a good way to go, at worst I'd need to replace a set of burrs and maybe some assorted lids/hoppers etc. I must admit some envy for the MACAP MK7 :D although it's quite a bit more expensive than even a new Super Jolly--I've read the TGP and it's not clear to me that I would really be able to tell the difference between the two.
I've discounted the Mini because even comparing new prices for each it's not that much less than a Super Jolly and from what I can tell folks think the latter does a much better job. The MACAP M4 series seems to be in a similar situation, although the head to head comparisons are fewer.
I'd be interested in any experiences with purchasing a used grinder from eBay as well as other ideas.
Thanks in advance
Pat
CaptPat
Link to "The wisdom of purchasing a used grinder from eBay"by jesawdy on Sun Nov 04, 2007 11:01 am
With all the usual caveats (buyer beware, check feedback, opt for insurance and other buyer protection), I think it is an excellent option. I have purchased three used commercial grinders by various means, (two Cimbalis and one Mazzer SJ).
Be patient, wait for a clean one and good seller feedback. Ask questions. I am a big fan of fairly priced Buy-It-Now auctions, it simplifies the whole process and everyone leaves happy. For the Mazzer, I could care less about the hopper condition, as you'll probably not want to use that huge beast. The rest of the Super Jolly is built like a tank, parts are prevalent and relatively inexpensive (the Rocky pales in comparison in both regards). Depending on the wear and tear, it may need new burrs as you suggest.
Very clean used Mazzer SJ, paper cup hopper, tamper in cup for weight, disabled auto grind features
Jeff Sawdy
jesawdy
Link to "The wisdom of purchasing a used grinder from eBay"by TimEggers on Sun Nov 04, 2007 11:54 am
I say go for it! I got my Super Jolly on ebay and after a coat of paint, new hopper and doser lid and new burrs I have one nice grinder!
Tim
LMWDP #202
TimEggers
Link to "The wisdom of purchasing a used grinder from eBay"by caeffe on Sun Nov 04, 2007 8:44 pm
the usual caveat emptor applies .....
I bought a used burr grinder (Rancilio Jacky) which practically disintegrated on me upon disassembly due to its plastic parts. I think if you go into it knowing what the parts are that you may have to replace for it and consider that into your budget you'll be ok
Eventually, i ended up buying what I thought was a rebadged Rosito Bisani Super Jolly. Turned out to be a Mazzer Major. So.... sometimes you get lucky also
caeffe
Link to "The wisdom of purchasing a used grinder from eBay"by TimEggers on Sun Nov 04, 2007 9:05 pm
It also depends on what grinder your looking at. I'd jump on most any Mazzer on ebay. There are other grinders too that I wouldn't hesitate with either. But like I say it"s important to note what class of grinder you're looking at.
Tim
LMWDP #202
TimEggers
Link to "The wisdom of purchasing a used grinder from eBay"by NickK on Mon Nov 05, 2007 12:16 am
DOO EEET.
Be careful of course, but it's difficult to trash well-built grinders like Mazzers.
We have a Super Jolly paired with a Swift in the shop at which I work, and although I prefer the Super Jolly, it is slooooooooowwww. It doesn't bring across the same flavors that a Robur does, either. Roburs are overkill for home (maybe) and the speed isn't really an issue there, but definitely get the best grinder you can.
You WILL be able to tell the difference between grinders. Don't underestimate your palate.
NickK
Return to Espresso Grinders
