erics wrote:I wasn't necessarily shooting for 0.6 bar (but that's where it ended up) rather I was going for ~ 198 F group temperature. Steaming capability is still there at 0.6 bar but obviously not quite the same as 1.2 bar. Machine recovery, back to 198 F group temp, after pulling a "real" shot this AM, was a little longer than desirable - about 20-25 minutes. As others have said, the PID'ed hx does give you a lot of control when trying out different beans/bean blends and most definitely it will provide very repeatable results which I view as a most desirable attribute.
this sort of relates to my thread that youve been really helpful in. I havent had time to experiment further, but, at 0.7bar, some coffees are great, and some are terrible. HX inconsistency, well, rather, its tight deadband of temp/pressure, seems just too limited for my tastes. for now, ill try to work with it, but long term, like you said above, try a double boiler or so.
anywayyyyy..onto the meat of my post.
you chose your boiler pressure based on a group temp of 198. do you find that group temp ideal to pull shots without a flush, or, just a really short flush?
from what ive seen at 0.7bar, group temp is around 205(ish) and the water appears to start at a fairly low temp, around 155, then creep up to 198ish. im assuming it stabilizes around there, cant recall.
but, again, without a longish flush, youre still going to get temp instability. itll either drop at boiler pressures of 1.1 bar, or raise at 0.6 or 0.7 bar. your chart shows youre still flushing around 4-5oz in those 6 seconds or so until temp stability is maintained, or, are you actually pulling the shot from a cold start, and just letting the first amounts of coffee to be extracted cold?
that brings up another issue, if stability isnt maintained across the entire time of the shot, isnt final outcome affected?
so, start colder and increase, or start hotter and decrease. in the end, does it matter?
i think what im driving at, is that there must be an ideal pressure/temp crossover point where stability between grouphead temps and water temps are close enough that flushes are small and stability is maintained, and, of course, the results tastes good.
question is, what the hell is it!
lots of questions, huh?!
