Psyd wrote:What confuses us is why you'd be so concerned that some of us either: 1) need to do more to make decent 'spro, or 2) want more than what we're getting from First-a...
So, what is that about?
We agree
some need to do more to make decent 'spro.
The relevant question at hand is what is
more and what is
less.
First, let's 'demolish the polish'.
In one of the above images, the puck is polished. Each had a single drop of water applied at the surface and the photo snapped within ~1s. There is no discernable difference to the naked eye or when viewed with a 10x loupe.
I first learned of the 'polish' on the internet many years after my first self-pulled espresso. Erroneous thinking led me to believe, and I stress
believe, that techniques may have improved over the ensuing interval. I tried all manner of polishes as described on the web. Discerning no taste difference in either direction, I embarked on a test series to determine what effect polishing might actually have. As there is no difference on the spent puck, I surmised that any positive effects must occur in the earlier stages of the extraction. I truncated extractions down to the minimum I could reliably run the pump, about 1s, and examined pucks. There is absolutely no difference whatsoever, polished or not.
Next, let's 'knock the crap outta the tap'.
Unless the rules have changed, distribution is a key parameter in pulling a shot. Simple physics dictates that if one taps on one side of the puck, the distribution is changed. Tap twice and change it more. Now if one taps
equally and at exactly 180° in exactly the same plane, one still cannot reverse the changes as the mass distribution is not the initial condition. Realizing that the likelihood of restoring the puck to its initial state is well nigh impossible, it seems prudent never to begin a tapping regimen.
The polishers and tappers have claimed 'cleaning' as a benefit.
Firstly, if there was any benefit, it accrues on subsequent shots, not the current.
Secondly, simpler, quicker and more effective cleaning operations are available.
By all means experiment with things that make a difference :
Large : Coffee, Grind, Dose
Medium : Pressure, Temperature
Minimal : Tamp,
assuming it's level
Once the above is exhausted...
My 'concern' is that a too large percentage of Home-Baristas fail to grasp the above. Wading through mountains of threads like "Grind Setting for..." and responses to "Why are you doing that?" of "I dunno, I saw..." frosts my biscuit!
If going through the motions makes one
believe the espresso is top notch, so be it.
Some
know otherwise.
"Some men are just as sure of the truth of their opinions as are others of what they know" - Aristotle
"Make everything as simple as possible, but not simpler" - Albert Einstein
