coffee_monkey wrote:Based on my experience and what I've read, it had to do with the type of roaster (and the heat source it uses) and the roast profile, which results in different heat transfer rate/efficiency than most home roasters.
LeoZ wrote:So DRUM > AIR?
coffee_monkey wrote:direct flame drum > semi hot air drum > air
Roast profile also have a great affect on it... largely due to what you've done to the bean cell structure in your roasts. In a overly simplified explanation, faster roasts tend to shred up the cell walls whereas a slower/longer roast preserves the cell structure.
coffee_monkey wrote:You can't ask the roaster to what it is not. That is simple physics. You can attempt to duplicate the roast profile but heat transfer method is still different. It is what it is.
Just roast less and more often.
expanding on my original question, how much can one extend their home roasting profile to mimic bean lifespan of these setups, without sacrificing flavor?
LeoZ wrote:another far stretch, buy lavazza. ok, not ideal, but still a great tasting bean, and not anywhere as flat as a homeroasted bean would taste, especially after 2-3 months!
another_jim wrote:One factor is that pro roasts come in valve bags, while home roasts are mostly stored in mason jars. This, along with less than perfect profiling will make the difference.
Branden wrote:I have often wondered what the effects of a sealed mason jar are and how this changes the way a bean stales. When I open a mason jar, for the first few days the smell is rather flat while in comparison when I store my homeroasted beans in valve bags the aroma appears to develop to a much fuller extent.
What are the effects of CO2 that is trapped within a mason jar until opened?
Branden
Kaffee Bitte wrote:And on similar lines. Are jars with one way valves a good way to go?
DaveC wrote:I've always thought so, and you can make reusable ones.
luca wrote:This might well merit a separate topic, but one thing that I have mentioned before as intriguing me is that commercial drum roasters invariable start with a much higher drop temperature than most home roasters. Could that have something to do with it?
